Brake lights
Hello, brake lights have stopped working on my Fabia Elegance MK2. Both bulbs are fine. Brake light stip on top of the boot door has never worked. Would appreciate how I can these working again, many thanks.
What year is your mk2?
Whereabouts in Berkshire are you?
May be a failure of the brake light switch on the brake pedal, plus a broken wire in the bellows between rear hatch and body for the high level one.
Hello Breezy_Pete,
Thank you for your quick response.
Fabia is 2004, estate version.
Retired to Ireland ( profile just updated!).
Will find some more info on switch on brake pedal.
Had a quick look at the bellows wiring - all seemed fine, but will investigate more thoroughly. ( Not required for the MOT I believe).
Kind regards, Richard
Recently Browsing 2
