Rear ARB
Can anyone reccomend somewhere that i would be able to get a rear anti roll bar to fit my 1.8T elegance please???
Also seeing as it has vRS springs and dampers will this make any difference???
Neuspeed one should fit yours or any other.
Doesn't take long to fit,just a bit fiddley getting the clamps on other the rear beam.
Doesn't take long to fit' date='just a bit fiddley getting the clamps on other the rear beam.[/quote']
where can i get one??
and how much is it??
Got mine from awesome.
My rear ARB is 28mm with standard 19mm bar on front.
If i was you and didnt want to uprate your front bar then go for the 25mm rear neuspeed bar.
I am sure my front ARB is 23mm as standard cos i measured it the other week.
Mines 19mm on 52 plate VRS.
If its 23mm then go for the 28mm bar.You will notice such a difference.
I've the Neuspeed adjustable 28mm rear ARB....set it to the medium setting and no real need to uprate the front arb....then again mine is lowered so perhaps that's why.
Will still get understeer if push very hard in the dry.
Hardest setting apparently will give lift off oversteer.
What size is you front arb?
Mines set to middle setting as well.
No idea...it's a 52 plate RS so I'd guess at least 23mm.
mine is a 53 plate elegance
does that sound right to have a 23mm ARB on the front as standard then???
Easiest way to find out,phone your local dealer and they can check for you.
Mines a vrs and only has 19mm front bar on.
Easiest way to find out' date='phone your local dealer and they can check for you.
Mines a vrs and only has 19mm front bar on.[/quote']
I measured it myself a few weeks ago and am certain it is 23mm, just wondered why mine would be 23mm on an elegance model and yours would be 19mm on a vRS ????
Sarah, does the ARB you have quoted me for fit both the non- vRS models and the vRS.
I am really unsure as to which one to get as i have vRS springs and dampers on my elegance
Same subject "peeps" ,,,,,,,,,,
What about a rear ARB for a 4x4 Estate ,,,,,,,,,,,, anybody ,,,,,,,,,,,, ??????????
Sarah ????????
I measured it myself a few weeks ago and am certain it is 23mm' date=' just wondered why mine would be 23mm on an elegance model and yours would be 19mm on a vRS ????
I am really unsure as to which one to get as i have vRS springs and dampers on my elegance[/quote']
Hi
The vRS is different to the non vRS
These are listed on the web site.
Neuspeed Front Anti Roll Bar (not VRS) 25mm SU-ARB-NEU-GO4B
Hi
Yes the rear is the same.
Just go for the 28mm rear bar.
If your going to BBQ next week you can have a go in mine to see what a difference it makes.
My boss (hes got mk1 vrs) have a go the other week and couldn't believe how it drives.
I can't make it to the BBQ, taking my son to see Thomas the tank engine live at Sheffield arena :thumbup:
I am going to go for the 288mm one though. Did your insurance increase by much by fitting it???
Insurance didnt increase on mine.
looking at that list i would say the front is different but the rear is the same.
You see you dont need me :)
Yes it is the same , just the front that is different.
We have these in stock too.
If I can help you , just give me a shout
Sarah
Blimey ,,,,,,,,, just about 11.5 inches ,,,,,,,,,, that should stiffen it up somewhat !! :D
lol
only just seen what i have done there :rofl:
looks like i may be postponing the ARB til i have sorted out some new wheels.:(
