Rattle from rear plate
Hi just picked up my new octy elegance tdi est. Pretty happy with it on my runs today but have noticed when i close the boot that theres a loud tinny rattle from the number plate is this normal?. Also have a clear plastic clip attached to the driver side upright of the windscreen, is this just from not being rem at del or is it necessary???
Cheers for any help
Also have a clear plastic clip attached to the driver side upright of the windscreen' date=' is this just from not being rem at del or is it necessary???
Cheers for any help[/quote']
It's for sticking tickits in..........:)
Well i best not prise the clip off then!!
Check theres a padded strip on the car behind the number plate. Its supposed to be on it
In any tools shop you can buy double-sided tape. Remove the plate, put the tape on, put the plate back on. It's simple
Mine just had one of the screws loose [beneath the round yellow plastic cover]. Tightened one turn and all okay
Great replies will check the plate asap. Well p'd off though as drove to lakes today and ended up with a stone chip on the screen, not fatal though.
