1.3L felicia thermostat
Hi everyone.
I recently bought a 1.3L Felicia 5 door hatchback, 1998.
It seems the thermostat has gone, which seems like a common fault on these.
Anyone know where you can pick up a cheap thermostat?
Thanks in advance
hey there,
I dunno what the thermostats on these things are like but can u not just take it appart and clean it with hot water etc to try an fix it? Also i recently bought a sensor one of these for jus over a tenner from local motorfactors (assuming is same as Li) hope there is something of relevence in there for u :P
If yours is the plastic thermostat housing (which being a 98 model should be) it will cost around £50 from a main skoda dealer. If the clips have broken inside the housing like mine did, u will need to replace the full housing. I brought an older thermostat from JHM Butt and it was for the alloy housing, which i didnt realise til i got it. Very easy job to do yourself. hope this helps
Thanks for that.
I have got a thermostat and housing from the scrapyard.
When i install this on my car are there any seals or anything like that i need to get?
or is it just a plastic to plastic fit.
Also, to what torque should i tighten the screws/bolts that hold the housing on.
Thanks in advance.
ps - just to clarify, i am only swapping over the plastic housing that holds the thermostat. The housing is held by 3 screws/bolts, with one of these screws/bolts also securing the dip stick.
there are some seals that are situtated on the ends which u should be in the housing, mine got stuck to the engine so i just peeled it off and stuck it back on. they are there to stop the coolant from leaking out so if u haven't got them, u better get some. I brought the thermostat new so i got all mine with it but as long as they are in decent condition, u shouldn't need to replace them.
im not sure about the torque settings as i can't find my haynes manual. if i can find it i will let you kno
Hi!
Faulty thermostat is a common problem with the 1,3L engine. I have now my second Pickup and I have experienced this 4 times now.
At the end I went and bought a non-original part. And in this part the spring is not retained by some f..... plastic....
The thermostat comes in a steel pack with springs and everything. After putting this part in I have had no problems in the last 3 years!
Can't remember who made the part...but I can check it out.
thermostat cover bolts 10Nm or 7lbf ft and thats from the haynes manual
