Hot or Cold Tyre Pressure
Should you really check your tyre pressure with warm or cold tyres?
The difference between 5C and 30C could make somewhere in the region of 10% difference according to my calculations!
Whats the textbook answer?
Jono
Cold I believe, there again Cold in Winter is a lot colder than cold in the middle of summer so I guess someone somewhere will know what air temp is deemed cold!
The biggest problem I have noticed is the vast variation in gauges in Garages. I tend to try & use the same Garage & keep an eye on tyre wear/grip & adjust accordingly. The answer probably is to buy your own tyre gauge & carry it with you but thats all a bit too specific for me.
Stuart (must do some work)
Always cold plus I always carry two accurate gauges. I'm slightly obsessed with tyre pressures. :new_silly
Only when cold. There is more tyre info from Dunlop on that site for those who are interested in learning more.
How warm are tyres likely to get on a trip down to the garage?
Jono
Negligibly. Just don't check tyres after the car has been parked all day in the hot sun or after a long fast drive, especially when the car is laden.
Always check tyre pressures cold.
I've noticed, using a modern digital pressure gauge, that "cold" tyre pressures can vary with ambient temperature. The variation is enough to make one or (occasionally) two digits difference to the reading; it's also visible on an old-fashioned "pencil" gauge, though nowhere near as obvious.
