(!) on 1.6 GLXi dashboard intermittently flashing when driven
Hi there...
Could anyone clarify what the (!) symbol on the dashboard of my P Reg 1.6 GLXi Felicia is for:confused: ? It is currently flashing intermittently when driven and seems to be influenced by steering column movement and throttle pressure.
The car seems to drive fine but not sure if it is a loose connection or if the car may need attention:confused: ? Unfortunately do not have access to a Felicia Owners Manual..
any help appreciated...
thanks :thumbup:
Simon
It's the brake fluid warning light. it should indicate that the fluid level as dropped and needs topping up.
HTH
AndyC
thanks very much..will get it sorted ASAP
Thanks...had the brakes pipe / shoes etc. replaced about 4 months ago...added dot 5.1 brake fluid reservoir and this has solved the problem... cheers for the feedback
Simon
