Help !! ZIELFUEHRUNG NICHT AKTIV
HELP !!!!!!!!!!!!
Our Superb came up with the message ZIELFUEHRUNG NICHT AKTIV in the message window, no warning lights & when you turned the ignition off & back on it cleared.
Anyone translate it ??
I think it's German for Sat Nav not active.
Guidence not active.
Sat Nav basically, but the language isnt set correctly.
It's uncanny, I just logged on the post about this! Mine does it probably 1 time out of every 5 times that I fire the car up.
Nothing you can do about it I believe. The SatNav language is set correctly. I guess it's a start up bug in the satnav sofware. A mate of mine's does the same.
The other thing is that the message doesn't time-out and revert to the trip computer, it just sits there until you physically switch to the trip computer display.
Rob
Could be a dash coding issue.
Mine does this on occasion, I sometimes lose the radio display too, not sure why. Just live with it now tho.
i get this sometimes. Just turning the Radio off,and back on again seems to cure it..
thanks
Looks like the wheels arent falling off then !!
I get exactly the same problems with my sat nav too
Me too. Just turn the radio on and off seems to clear it.
also sometimes the cd player stops working when you change track/disc and plays the radio instead!On the display for the cd player some discs come up NO CD,but still play!
  • 7 months later...
Hi its nothing to worry about. Ive found if ive navigated somewhere and the Dash is in navigation mode instead of trip counter, when you start the car again it seems to pop that message up. I think the dash display is basically saying no route active.
