coolant
hi all
quick one, if i remove bottom hose from radiator will it drain all the coolant from the system
Pretty much most of it.
in the haynes manual, there are two nuts to drain the coolant, one on the engine block and one on a metal pipe leading from the radiator under the car, i just opened these up and coolant is as good as gone.
