how about afan behind OE intercooler?
hi i have noticed the dis advantages using the front mounted intercooler in various forums why not try a fan behind the existing OE INTER COOLER? WILL IT BE OF ANY HELP? can we explore pros& cons
it would no difference at speed only at idle as a fan probably couldn't maove more air than your car doing 50mph+
what disadvantage of the FMIC are you thinking of?
as allready said above it's probably not necessary to have an interccoler fan..... unless you are doing hillclimb rallying or towing a caravan a lot.
I assume you're sighting the cost of the FMIC as the problem?
