Fabia on bio/chip fat fuel ?
Hi all, if i was to go down the road of finding a supplier for bio fuel or cooking oil what would the specs be, mixture wise and any other info regarding a 1.9SDI fabia running on it......any good?
If so then how do you find a supplier ?????
Cheers,
Kevin
Is the SDI a PD engine?
My VRS was ver poor at starting when I tried it. Smelt like a chip shop!!
Did you try a search?
Be warned there are lots of difference between Bio and WVO (Waste Veg Oil) or cooking oil.
Lot's of threads on Bio on here.
http://www.briskoda.net/forums/fabia/vegetable-oil/66238/
http://www.briskoda.net/forums/fabia/veg-oil-vrs/62119/
Mixture wise SUK say 5%, you should be good up to about 40% which is what I have been running although i am currently on about 25% (Or 10 ltrs per fill) due to the cold.
BTW mine runs like a dream on it, it starts fine drives fine and there is ample power. You will have to change your fuel filter on a more regular basis though.
For a supplier try...
agents
I used veggy oil on my sdi at a 30% mix, its great, car is quieter too :)
I have msn if u wana chat more about it
Hi Stuart_Hatch, would love to find out more cos i would be up for a greener use of car also cheaper to run ???.
Thanks Decron for the link to suppliers, theres 1 in bradford where i live so will be talking to him soon......will let you know what he says.
NottyAsh, how do i know if my 'Y' reg Fabia SDI ( 2000-01) is a PD engine, where do i look to clarify this.
So in thiery after reading the links you just add bio and deisel and hey presto, nothing else......
Kevin
The SDI is not a PD engine, just conventional direct injection from a common injection pump.
