Which service does my VRS need?!
Guys, I'm confused about which service my car needs, and the dealers are making the situation even more confusing! The history of my car is as follows...
May 2005 - First Registered by first owner
May 2006 - Bought by myself with 3,300 miles on the clock and serviced by dealer
Dec 2006 - Now approaching 13,000 miles
I presume as I've covered nearly 10,000 miles since the previous service, the next service is due? If so, does anyone know what service it is? I've called several dealers, some refer to major/minor services, others refer to 10,000 and 20,000 miles services, and others refer to 1st/2nd/etc service? WTF?!
One dealer quoted
Hi Mate
1st service minor service or 10k service is all the same
2nd service , major service or 20k is the same
I would do a minor service and we would charge £114 + VAT for that
Brake fluid too I would do
That is required every 2 years
I know your car is not 2 years old , but if it takes another 6 months for the next 10k miles it will be over
I would not let the brake fluid go over 2 years
This is just every 2 years and mileage is not applicable for it
Go with a VAG speciallist as their prices will be cheaper
That will not invallidate any warranty available on the car either
Hope that has helped a bit
Sarah
:confused: It is a bit expensive I agree.
Try different Soda dealers, they do vary.
I paid
Ahhh, what you have there is the "Magic inspection"
Part of the service is a full 1 year or 10k inspection of the whole car and it puts the cost up. if it is a year since the last service then it should be done as it's part of the shedule.
If it's under a year you can just specify the lube service it should be under
If you're going to hit 23k miles before next May, then you can just have a lube service (oil change) and defer the annual inspection and brake fluid change until the 23k service. If you're not, then best get a full service done (inc annual inspection and brake fluid) at this service.
Certainly ring around a few dealers and bounce quoted prices off them, or go with an independent specialist....
Chris
The car will be due an annual inspection service in May 2007.
Right now, it needs a 10K oil change service, that's all.
