Forge 007 or Bailey DV30?
What's the general opinion here? As suggested to me, the standard recirc' valve is not enjoying the increased power on my 1.8T. I intend to purchase either the Forge 007 or Bailey DV30 - Both are direct fitments. I am struggling to decide between the two at the moment. :o
Hi
007P everytime for me
Excellent piece of kit with excellent back up from Forge
Sarah
Thanks, do you know what the difference between the 007 and the 007p is? I have not come across it before and a quick google search found it but didn't highlight the difference.
I've got it logged that mine is a 007PA!
I'm sure if you check the Forge website, all will be revealed.
one has a fixed outlet and the other rotates apparently.......
That's the one ,,, mines a rotator. :thumbup: ,,,,,,,,,,,,, apparently.
show off.
Thanks! Does anyone know if the 007p (non rotary top) will fit under the standard engine cover without modification?
well i had a turbo dynamics viper(i think) that looks the same dimensions but bigger and that fitted under there.
Yes the Forge one will fit under the engine cover
We do the 007P at £72.45 + VAT abd retail is £80.50 + VAT
They are also in stock
They do a bling silver one or a matt (ish) black one
Sarah
Thanks bengie and Sarah, I will order one from tha awsome site when internet explorer lets me on there! :)
I had to cut my cover, but it does look good, all nice and shiney sticky up thingy.
  • 10 months later...
We do the 007P at
does anyone have a link to a how to?
cheers,
Shaun.
Is it a straight swap ? for original
Hi
Yes it is a straight swap :D
Easy to do , even I can do it
Sarah
What about a Forge SpitR, or whatever it's called, surely that's worth considering too?
The SplitR was developed for the noise
This is the ONLY atmospheric valve that can be used on the 1.8T engine without bringing on warning lights
It is more expensive than the 007p but then if you put a 007p on upside down with a CAI you will get the same type of noise
Hope that helps
Sarah
