Bonnet Won't Shut Properly?????
I have just bought a 1999 T Felcia. The only problem I can find is that the bonnet is not shutting properly. There seems to be some slack in the cable and the release handle seems to easy to pull and push. I have followed the cable back from the bonnet latch but don't arrive at anything I can adjust away the slack.
Does anyone know where this adjuster may be as I don't have a haynes??? Or is it a case of no adjuster and replacing the cable???
Thanks in Advance for any replies.:)
On ours we just had to replace the cable.
its a difficult shift, involving lying upside down on the passenger seat to get access to the handle
:iagree:
unfortunately the cables seem to stretch and there's no satisfactory way of adjusting them!
No worries. Thanks for the quick responses.
Are they easy to replace or is it a garage job?
Is it a part that can be sourced at Halfords or a Skoda only job?
I only ask as my nearest Skoda dealer is not so near!
yes, if your're triple jointed in both arms, and can lay head first in the drivers footwell!
95p + vat + postage from jhmbuttco.com
TEL: 01302710868 or [email protected]
Around
If it's not actually shutting properly, do you mean the catch isn't holding it fully shut. If so maybe the catch is stuck open and needs a bit lubing and freeing up. I seem to recall mine was quite dry and stiff when I got it. I also find that the bonnet never fully shuts when I 'drop' it down. I have to lower it so it rests on the catch and then push it shut firmly with the palm of my hand.
Yes a bit of WD40 seems to have free'd it up a bit. Can shut it if I press down with my hands as you describe. Cable still seems a little bit slack, but as long as it works for now, I can sort it out after crimble when it's not so baltic!
Cheers.
