Fabia Wheel Bolts
Does anyone happen to know the shank length of the standard fabia wheel bolts?
Also if anyone has fitted any team dynamics alloys did you use the skud bolts or buy some longer ones?
Thanks!
My Pro Race 2s came with their own bolts. The McGuards are labelled M14 x 1.5, which probably doesn't help you.
Bryand has raised a good point in his post. VAG wheels (be it steel or alloy) use radial bolts (the curved face) and most aftermarket alloys use a tapered bolt (the other bolt). Fit the wrong bolt and you do not have the correct surface area for the bolt to tighten onto. Worse case is the bolt comes loose (seen it happen).
bryand- Thanks for that, tney look like the McGards I have.
I need to speak with Rimstock as the spiggot ring seems far too tight on the hub, I'm not sure the correct spiggot ring was fitted by the previos owner (he used spacers). Halfrauds are ordering the 'correct' bolts but I'm not sure how much I trust there expertise!
