vRS delocking kit??
Anyone have any ideas where i can get a delocking kit for an 04 vRS from? (part numbers would be most useful!!)
If you simply want to hide the key barrel, you could get chrome door handles from Milotec and cover it up.
of get a rear door handle instead?
the idea behind a locking kit is to remove the key locking mechanism from the door... covering it up with some plastic isn't my idea of secure!! my friend has a mkvi Golf anni and his locking kit comes with aluminium inserts to replace the barrel entirely... the plastic plate goes over this to blend the entire door handle....
what about replacing the whole handle?
the handle is standard across the whole 99-2005 VAG range, I beleive. can be found on Golf, Polo, Bora, Passat, Ibiza, Lupo etc etc
You didn't make clear whether appearence or security was your objective.
In 7 years of Fabia ownership I've never come across the sort of kit you describe. It's possible that components from other VAG cars could be used, though.
As babs said would not a rear door handle do...it has no keyhole...or is it just hidden.
In that case , buy the same kit , it is the same door handle.
