felicia brake caliper dimensions
does anbody have an accurate measurment for the brake caliper mounting centres please??
failing that does anybody have a spare hub/bearing assembly i can have so i can examine it for measurements..... i've been approached by a member about developing a big brake conversion;) for the felicia/favorit.....
so, if you've got one kicking around, even if it's knackered, let me know!!
also if there is anybody else interested please say, the plan is to use 4 pot caliper and corrado g60 (280mm) discs, and some custom manufactured mounting bracketry, so if i need to get make more than one set i need an idea of numbers:)
how about a rear disc convertion????
it's been done before!! you can occasionally get the complete kit off ebay
there doesn't seem to be much interest in this so i'll add a picture to wet your apetite
these little babies retail for about 120 quid each!
would it sound wrong if i said i was all excited???????
No it's perfectly acceptable to be excited by automotive pornography. I'd be intrestead in a big brake kit, I have a pair of Wilwood calipers on my Metro hillclimb car and they are brillient.
Just one thing, What size wheels would you need to run to fit over this conversion? I'd prefere to stay on my 13x7s for obvious handling reasons.
i was thinking 280mm discs, which shouuld fit nicely into a 15" wheel
ooh tom, you are one for leading a boy astray;)
nice set a willwoods, and a 1.4 lump, slammed on its nat king with bbs on it:D
you didn't mention the supercharger?
FI is for guys who have to make it all up on the straight cos they cant take the corners:rofl:
If anything, may as well compound charge it:thumbup:
