Superglue Removal
I had a bit if an accident in the car today. I spilt a small amount of superglue onto the dash ( on flat area just above hazard light switch). I've tried acetone (nail varnish remover), white spirits,soapy water and nothings working. When it dries out it leaves a white stain about an inch square on the dash.Any other ideas anyone? Most annoying.Regards David
Try to get hold of some "skin release agent" (or similar name) specifically for superglue - some hobby shops carry it. As the name suggests, it's for unsticking you if your finger (or whatever) gets stuck to something, but I don't see why it shouldn't work on your dashboard.
It works by being even "stickier" that superglue, so it displaces the superglue bond. Here's the clever bit, though - it doesn't set, so once the superglue has been removed, it can be washed off.
Another suggestion - if you can get under an edge, try peeling it away. Superglue has quite a low peel strength.
Best of luck!
How about a dremel?
How about a dremel?
:rofl:
Angle grinder will get it off. :D
Or go to Homebase or somesuch and get some superglue remover.
Angle grinder will[/i'] get it off. :D
:nono: This is a Forum for serious discussion.
(Got a new toy, have we? :rolleyes: )
If you think thats bad my little boy left a room air freshner upside down
on the tele the stuff leaked out and melted the tele case.
Dave, i had a similar thing when an air freshener leaked on the dining room table...
As for superglue -
A cloth dipped in vinegar will work for normal glue, but i'm not sure about superglue. Could be worth a try.
Or....MC2? :rubchin:
Denis, hence why I suggested:
It's what I used to get superglue off my dashbord.
Denis' date=' hence why I suggested:
It's what I used to get superglue off my dashbord.[/quote']Yes, I had noted that, Jon. I see you are still having trouble displaying your signature. Try dynamic blue for a more eye-catching presentation.
