Commodore Gaming PCs
Ok , so it's not really anything to do with the real Commodore , but they do look like nice machines and have a very good spec.
My credit card is trembling in fear.
PC Webshop
Nice! I like some of the C-kins. How much do you think the Commodore XX is gonna cost though?
I reckon £4000.
And it is something to do with the real Commodore, they even have a retro Commodore C64 "sick beige" clour C-kin.
Having acquired the Commodore brand in late 2005 as part of a joint venture with Commodore International Corporation, Commodore Gaming aims to re-establish the brand as a leader in its industry.
It's going to be scarily expensive for the top system - you only have to look at high end Alienware machines for comparison.
I still want one though :D
I wonder if someone will aquire the Sinclair Spectrum brand and come back with a top spec Speccy? Now that would be cool...:rofl:
Alan Sugar ended up with some of the rights to the spectrum brand after they used their emailer phone as a spectrum emulator
Twin 768MB 8800 GTX's. is that really necessary?
Of course :D
Could do with another 2 GB of RAM
Edit: not reading specs properly, already has 4GB
Still, antoher 2 GB RAM would be a good crack :rofl:
All that computing power and still an errant apostrophe on the website, tsk.
Not bad though *drool*
Not with XP or Vista 32bit, the max memory the operating system will use is 4GB. Put more in and windows will still only use 4GB.
doesn't PAE go at the very least some way to get around that?
Yes.. but thats only really suitable if you were going to use a single application that had some uber memory requirements, windows just isnt really configured(as standard) to use it properly.. hence using the /3gb variable on servers that run powerful apps (like exchange) to tell windoze to increase the maximum available memory that it will allocate to proccesses
My two PCs at home are roughly where the GX is at, but with faster memory, and hard disk setup. Would be interesting to see prices..
As for whether or not two 8800GTXs are needed - that depends on your screen, if you are running a LCD panel - probably not. I play games at 2048x1536 with all the whistles and bells on I get the odd frame rate drop with a single 8800gtx. Dropping the resolution down to 1920x(1440?)cures these near enough completely. If high resolution gaming is your thing two of these cards definetely have a benefit over one, but if you are still playing at 1280x1024 then one card is all you need.
Those motherboards arent cheap :D will be interesting to see prices...
Actually quite the opposite - each normally-written process will still just see 4GB, but the switch allows you to run several large apps on the same machine.
No, it simply adjusts the split in the flat view each process sees between kernal memory and the private memory of the process.
Give it a moment and the cheezemonkhai will elaborate if necessary :D
we've fallen foul of the /3gb switch here......... especially with exchange
What does that mean then :P
I only specialize in the PCI/PCI-X/PCIe side of it :)
