Project Q-Felicia
almost ready to go back on
  • Replies 538
  • Views 80.4k
went to the scrapyard today and got a few little connectors so i can make up a wotsit for the wideband lambda reader when it arrives
turned it into this
had to make a small modification to the wiring loom also
Going along well then :)
not going at all at the moment:O
the exhaust is still not on because the mounting rubbers were shot, so i have to wait till they arrive before i can re-fit it:)
started stripping the interior today! :D
more progress :D
You going to drive it standing up?? :rofl:
I'm guessing race seats and minimal sound proofing plus a few other bits to strengthen it.
even more progress :D
trying to figure out a way of bolting in these bad boys, hopefully it should be possible to re-use the existing seat frames/runners
there are two different types of exhuast mounts
Hmm the right one looks like a fiesta one, but then they are just big elastic bands.
zorst is on
hopefully the wideband lambda reader should be here tomorrow :D
Which will go faster, the Felicia in the foreground, or the petrol lawn mover in the background :D
Nearly together then. Any progress on the seat rails?
my latest project;) purchased from the tip as a non runner for a fiver..... now running :D might get 50 notes for it on ebay methinks
erm not yet no, i'm kinda concentrating on getting the engine running properly before i do anything else... i have made a few measurements of the oe seat rails and i think i'll machine up some pieces of ally bar to fit
:D it's here
made short work of installing that
then performed some electrical jiggery-pokery with my
:o can't believe it did this!!!!!
went into halfrauds to buy one of these
What is it? A manometer?
Does it light up or something (everything else from Halfords seems to... ;):D )
it's a carb balancer, it's kinda got like a little float that rises up awith the vacuum, you get a reading from the master pair, then stick it in the slave pair and adjust the balance screw till they it has the same reading
omg :rofl::rofl:
it's running a bit lean on the over-run so i'm getting flames from the exhaust on the over-run at the moment:O
omg :rofl::rofl:
it's running a bit lean on the over-run so i'm getting 2 foot flames from the exhaust on the over-run at the moment:O
Nice :D
Nice :D
not nice:O i'll end up melting the exhuast valves if i carry on like that, or end up busting the brand new lambda probe
