Exhaust Modification
Just a thought as I can't sleep...
What mod would I have to do to make the car blow smoke rings?
Discuss...
nn xx
:rofl: still awake (sorry me bad :( )
Could overfuel it a bit by booting it low down in revs - tends to give nice clouds of smoke :D
proper smoke rings like a cigar could be tricky :D
caster oil is good for creating smoke, cant think of a way off-hand of doing it in rings tho
You need a Gandalf exhaust - no, he blows the ship
It's Bilbo that blows the rings, that the ship slips thru
That's the affect I was hoping for...
I am trying to be a bit more sophisticated...
If I only fitted one head lamp guard, would my it look like my car had a monicle?
I can already make smoke... I want smoke rings :D !!
then all you'd need to finish it off is tartan wheels
You could do a brow (sp?) on the other side perhaps :D
Just kicked up google to have a look if there is anything about, this one is kinda fun to investigate. BUT gonna drop food in microwave first :P
For insurance purposes would it be a performance or cosmetic mod?
Cosmetic.
The creation of rings of smoke will bring no performance benefit.
Steve
Urm - not a clue :D
What does a flamer kit fall under, think it might just be classed as an after-market exhaust or summit :D
You could use a jet engine instead, this is a tad of a crazy option but it would make the car accelerate :o
I reckon if you had a rotating disc to collect the soot from the center and drop it into a circle shape by closing a valve at the back, it might even work :D
Thinking of something where you'd have two rings.
One is outside, then gap of say 3-4 mm, then second ring. Then have a flap that can cover the hole in the middle when you want to have a ring. You'd get a very small gap as the valve would be coming in from the side I suppose.
It would probably cause a fair bit of backpressure but force the soot out in the gap between the two rings, might just do it
You'll be needing the "Ivor the engine" mod, mind....
Ch-ta-cuf, ch-ta-cuf, ch-ta-cuf etc....
It's a diesel, it should be taka-taka-taka (Mill ed ) ;):D
I think WW has nailed the principle.
:rofl: - I sure did something, no idea whether it was of any use though :o;)
Smoke rings ... I don't know, but flames from a diesel ..........
CLICKY
Not surprisingly there is a recall on :D :D :D
Clickety Click
BTW, that truck is standard :eek:
"If heat is detected, the s/w will power down the truck, so that the driver can pull over" - is it just me, or does this sound potentially more dangerous than the fault?
Maybe one of the site sponsers will read this and will make one!
We could do a group buy!
