Power Steering Sensor (G250) - 30-00 - Open or Short to B+
Does the PAS work without the engine running - no
So its pretty safe to assume the engine needs to be running for the ECU to output a voltage to the sensor.
Also testing a hall effect sensor with a bulb is no good, you need an LED test light.
Lummox - You are right - We were uisng a LED test light - Sorry I didnt know thats what they were called...
The engine was not on - But whats strange is when the engine was off the other two leads all had current - I ll try this weekend with the engine on and see if current is getting there -
If there is not current then what would you do (assuming another sensor still has the same problem)
Cheers very much
