Oh c^%p, this could be expensive
Smoke, burning smells, oil pressure warning light, car turns over but won't start, no communication with the engine control module and to top it off it ground to a halt less than 1 mile from home so no recovery. :(
Chassis Type: 1U - Skoda Octavia
Scan: 01,02,03,08,15,17,19,35,46,56
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 F
Component: ESP ALLRAD MK60 0104
Coding: 0023174
Shop #: WSC 31480
1 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication
Address 08 -------------------------------------------------------
Controller: 1U1 907 044 A
Component: CLIMATRONIC C 2.0.0
Coding: 11000
Shop #: WSC 31480
1 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
37-10 - Faulty - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1U0 920 911 B
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 23412
Shop #: WSC 31480
TMBKL21UX38689158 SKZ7Z0B1661545
1 Faults Found:
49-00 - No Communications
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 31480
1 Faults Found:
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 B
Component: 4Q Komfortger
No faults in 01 engine though?! :confused:
Probably plenty but I can't access it. Neither can any of the other modules by the looks of it.
do you want a tow home?? come round and knock on the door if you do. (the door bell doesnt work)
Oh no :eek: sorry to hear this - best of luck sorting it out :(
No mate, but a tow slightly further away from home could be good. :thumbup: You got a rope?
unfortunatly not. i have a warning triangle
i can give you a lift to a petrol station to get one, then tow you
I guess I'll see you in the morning!!:thumbup:
yeah, just pop round. if theres no reply we're either at the hospital or mucking out the horse. I'll PM you my mobile number just incase.
Got it recovered to JBS this morning and they've already had a quick look at it for me (cheers fellas :thumbup:). The ecu isn't dead :D just the power to it is shorting somewhere and blowing fuses. They suspect an electrical short in the main harness as it passes thru the bulkhead but so far haven't tracked it down. I think i'm happier but i guess its still too soon for relief.
And Kev has just been back on the phone, car is now fixed:eek: :D:thumbup:. Apparently, the coil pack on cylinder 4 has melted, melted the connector and caused a short. One new connector and coil pack later, the car is back to life. Absolutely top stuff from JBS, seriously bad stuff from Skoda. I don't think its very good that a failing coil pack could set fire to your car!
At least you now know what the burning smell was, hopefully no more damage will rear its ugly head in the future.
Burning smell accompanied with a generous amount of smoke!
