Less smoke, smoother engine for about 90p
What it's like further up the rev range?
Does the rev needle get to 4500rpm in the first three gears without slowing, for example?
Wouldn't know, no need to rev the boll***s off it, it's a Diesel, enough go for me up to about 3500RPM, any more to me is just wasted revs and fuel.
  • Replies 70
  • Views 7.7k
How much grease do you put in, just enough to cover the contacts or a really good covering?
Shove in as much as you can get, but not too much else it won't clip back together again ;)
4500rpm ain't revving the mechanical gonads off it.
Not in my car, at least. :)
I rev it so, during periods of brisk(oda) driving, only because the car asks for it. :D
And so what if 'it's a Diesel'? :confused:
My diesel, in the first three gears at least, is very rev-happy.
I take it yours isn't then? ;)
You say that going above 3500rpm is 'just wasted revs and fuel', but as my car's acceleration is constant between 3500 and 4500rpm in first, second and third, there's no benefit in me changing up earlier.
Indeed, were we to be side by side on the strip, clearly I would pull away from you. :P
And as for 'wasting fuel', if this really represents your mindset, then I think you are missing the point of having a vRS.
Personally, I'd go canny, as I've read some posts (possibly on the actual thread where the Cage Mod first appeared) suggesting problems when an excess of grease gets forced out the back of the plug and into the air intake itself.
Can't remember which models this is claimed to afflict, unfortunately.
Surely something like copperslip would do the trick? :confused:
Ive got sum artic silver compound (cpu thermal paste) would this be OK?
All the references I've seen specify silicone dielectric grease, nothing else. I got a hold of some CPU paste then noticed that it hardens, so had to wait till I went back to the UK to pick up a big tube from Maplins.....
HTH
Bas
Er, no.
You need an insulator, not a conductor, like what a slippy coppery goo will surely do.
Just get the real stuff here: Multi Purpose Silicone Grease > Maplin
And get the RE90X as this is the stuff in a tube, not spray.
Mindset eh?....Utter nonsense...... I have a vRS beacuse I like the way it drives and saves me fuel, it's nippy enough without reving it too much, well it is on the roads around Ashford.
Not everybody ownes vRS's to drive them like that.....;)
Mine easily gets up to 80 no trouble....
I think your mindset is a bit off thinking you need to rev it to those speeds in 1st and 2nd.....there 'aint no pull in first, second is marginally better, but I use third and fourth for any overtaking manouvers.
Also, have you had yours on a rolling road Mr Tickle? It is usual in a standard car for things to tail off after 4k. No point going past that point, if there isn't anything there.
Steve
Agree :thumbup:
Well, on the fine country roads and dual carriageways around where I live, revving to 4500rpm is practically de rigeur and something only a cad, or perhaps a bounder, wouldn't do.
Really? :eek:
I was actually made to sign a contract guaranteeing to drive like that 85% of the time.
Mine too.
And 100 (on a track). ;)
Really? :eek:
Mine pulls like a train in the first three gears.
Much like this guy's standard vRS (although third gear here seems a bit sluggish past 4000rpm):
I don't doubt it... second gear tops out at just shy of 60mph.
Steve
Booked in for a Power Run on the 11th of next month, as it happens.
I'm starting to think my car may not be standard after all.
A complete absence of smoke when giving it The Beans may suggest it is standard, though.
That and the fact its one owner before me was a retired gent who put only 8000 miles on it in four years. :)
And it's Mr Wobblytickle, Wardo. ;)
I think you're conflating me with that Brainiac guy.
Well Mr. Wobblytickle I just hope your cam belt has been done if it's 4 years old.
Out of interest....what MPG are you getting then?
You betcha! :thumbup:
Got a year's MoT, year's warranty, year's tax and a new cam belt (and it had just been serviced too!) when I bought it in July from a Skoda stealership in Edinburgh.
They took some cajoling to do the belt for free though, even though it is an 04-plate, probably due to it only having done 7910 miles.
Chancing bar stewards.
I pointed out that VAG were ordering belt changes every four years or whatever miles it is first (and that they would have received a service bulletin to that effect), but the stealership said they'd only pay for half of the work.
Yeah, right!
I got Skoda UK on the case and a helpful chap there said if they didn't play ball then they'd call them to sort it out.
The stealership promptly capitulated. :)
Over the last 3000 miles I've averaged 39.5 MPG.
Clearly, I wholeheartedly embrace the Skoda Driven Briskly philosophy on which this site is anchored.
However, I have been known to average 55MPG when travelling at between 50 and 60 mph.
Doesn't happen very often though.
I was thinking, would you like me to provide some video footage of my car pulling/revving out in second and third?
Might silence some of the doubters out there... ;)
I think that would be useful for people :thumbup:
Steve
I know that the effects of the pikey mod are disputed, just wondering does the 100 1.9PD have a SMIC? If so is it in the same place as the Vrs?
Yes it does.
Cheers for that
:offtopic: :rofl:
I have slapped some on my points too just now. Letting it dry off a bit before spraying on some more.
Shall see how it drives tomorrow. If any car could benefit from smoother performance, it's mine. :rofl:
