Fitting OEM Xenon lights to non Xenon cars
wouldnt wanna try and get the auto levelling to work:rolleyes:
There is a mod which changes the manual leveling to work instead of the auto.
Hmm so in manual levelling, I wonder if it's linked to the normal halogen dipped beam adjuster switch. If so, this could be interesting ;)
But this is just an adaptor, to plug into the OEM Xenon HID lights, so you'd still need the firing ballasts and all the other bits as well as the actual xenon headlight and bulb.
Perhaps it would fix mine up - mine are dead low right now, can't see a darn thing at night :( :(
get adjusting with your VAGCOM :thumbup:
isn't everything attached to the back of the xenon unit , i think it is on the Fabia , so the loom is just the adapter from the original vehicle plug (standard lamp) to the different xenon lamp plug
I would - Xav has my lead but there is a hard fault on the system, gonna have to try to battery disconnect/reconnect trick to see if it will reset :(
Fingers crossed :D
