EGR Valve
Mines due to be replaced, making noises that it shouldn't, have any of you had one replaced yet, and if so at what mileage?
Automatic or manual transmission? Which engine?
rotodiesel.
Auto TDi 130
The EGR valves fitted to PD engines with auto transmission are water cooled and appear to be less reliable than the "manual" version. Loss of coolant is another failure mode of these valves. I haven't seen enough "auto" versions of these to predict their reliability, but it's not very good.
rotodiesel.
Had it replaced today, car feels much better.
Changed quite a few when they leak oil, makes a right mess.
Funny you mention that, the vent holes in the sides had residue coming out of them, I just put it down to burnt carbonised oil, this time it was making knocking noises, gone now, had a new unit under warranty.
What's an EGR valve? What do they do?
Takes burnt gases and basically pumps them back in with fresh fuel for another go because there is still unburnt fuel in exhaust gas.
  • 7 months later...
Further to my "call me a tight sod" post, I took my Superb to an independant vw garage who was able to do the diagnostic for
glad you asked this - saved me doing it.
so guys:
where is it?
what does it look like?
and what are the symptoms, visual or otherwise?
:confused:
Open the bonnet and it's the metal thing next to the oil filler, when they play up it's generally one of two things, 1 - it's caked in old oil and gas residue, carb cleaner is the solution, or 2 - it will make a knocking sound indicating the diaphram inside it is split and then you need a new unit.
I assume that would be this thing (below) then? How would I go about removing it?
Remove the jubilee clip - the screw(s) circled red?
URL%5D
Would the failure mode of this also attribute to increased exhaust smells?
Possibly Simon.
I'll have a look when I'm over next. I'll bring my spare EGR with me ;)
Interesting you should say that, because i'm sure that I have noticed this - but until now I just put it down to paranoia. Also of a night time (when my headlamps are on) there appears to be excessive exhaust smoke coming through the front grill - again i've dismissed this as me being paranoid.
I don't have exhaust smoke from the engine and if that is a picture of your EGR Valve then mine is as clean as that..........I had put it down to the weather but now I am not convinced........:confused:
Don't be fooled by the apparent cleanliness of it - I gave it a clean (on the outside) last week.
Think they all leak in time. Mine is looking a bit oily these days but at
