On the shopping list - NEW PD280 engine with DSG
Might have to wait a while, as only just launched in a SEAT (ok so it's a WTCC).
ENGINE
Turbocharged, four-cylinder in line, transversely-mounted, 16 valves,
twin overhead camshafts
Displacement: 2,000 cc
Bore x stroke: 81 x 95.5 mm
Maximum power: 280 PS at 4000 rpm
Maximum torque: 450 Nm at 2500 rpm (330 lbft)
Lubrication: wet sump
TRANSMISSION
Front-wheel drive
Gearbox: Hewland six-speed, sequential shift
Clutch: twin-plate
Differential: mechanical limited slip differential
CHASSIS
Front suspension: MacPherson strut, coil springs, gas-filled dampers, anti-roll bar
Rear suspension: multi-link axle, coil springs, gas-filled dampers, anti-roll bar
Steering: power-assisted rack and pinion
BRAKES
Non-assisted dual circuit system
Front brakes: four-piston callipers, 332 mm steel ventilated discs
Rear brakes: two-piston callipers, 280 mm steel discs
SEAT entering first diesel in WTCC - Autoblog
Just for clarification, the Hewland 6 speed sequential shift is definitely NOT a DSG gearbox :rolleyes:
lol, very true.
Looks impressive though.
I realise that, but it is a Dual-Clutch Sequential Gearbox
Just some short hand ('cause whole description wouldn't fit neatly in subject box)
So I just stole some of the letters DSG (although a bit misleading it does share some of the same reason d'etre as the "real" DSG)
Its not a dual clutch, it just has a twin plate in it. ;)
again, very true, a Hewland box is just like a normal manual but with a sequential gear selection, nothing to do with DSG or 'semi-auto' or anything like that....;)
Oh - OK sorry
