Best Spark Plugs For Modded Octy Vrs Mk1
As title please guys..
Gonna go with the dealer quantum syntra 10w 40 oil just got to decide which plugs now..!!!
Cheers in advance all..
Denso Iridium plugs in my Octy vRS.
The part number for the plugs is IK20, (gapped @ 0.8mm).
Guy, at Opie oils supplied the plugs at a very good price, for my vRS, YZF 750R and the wifes KA.
I was thinking of getting the IK20's if I go stage 2 :D
I just had a set of normal plugs fitted though in my last service @
Opie oils have said that Denso Iridium Tough VK20Y's should be fitted to a modded Octy vRS ????????????
i wouldn't bother changing plugs unless you've done turbo/IC etc, just a remap i'd stick with standard ones :)
Cars running.. if this helps..??
Giac software
Forge cupra r/tt 225 inlet mani
Front mount int
k&n panel
bastuck exhaust not sure if sports cat.
Std ngk plug can cope right upto 250-280 so i wouldn't spend to much
ngk oe plug is pfr6q or pfr7q for a slightly cooler plug for higher temps.
As for the 10w40 if running 1.3-1.4 bar i would be inclined to put a higher spec eg
10-30 5w40 fully syn for better protction at high temps
