skodapink
hello! i need some info about heater plugs ?do you have to remove the injection pump to fit heater plugs in felicia 1.9 diesel . 1999 (t reg):confused: thanks g
you picked your site name well my friend.
cant help with the problem mind.
iirc you have to remove the injector fuel feed pipes
hi thanks for info will give it a try! and hope it will start on cold mornings or i will be walking to work. thanks again g.
just remove the injector pipes mate and then the glo plugs are easily getatable
thank you for your replys its time to get the spanners out !
thanks again g.
