creaky steering...?
new vRS tFSi, 3.5k miles
at very low speeds turning the steering wheel from straight ahead to the left there is a creaking noise like something rubbing. it was far more noticeable today when it was below freezing!
any ideas what might be rubbing, before i take it to the dealer?
//just read back a page or 2 and seen the other thread- i don't think this is the power steering pump as it happens through the range of movement, and not at full lock
I would get the dealers to take a look.
Could be drop links.
There was an issue with steering racks on some earlier cars but yours should be clear of that if it's a newish one.
My 2007 LHD vRS have the same.
I thought it is airbag ring, try to greeze it parts but it is not a solution. If you (or dealer) fix it - let me know what exactly you or they do. Thank you
Is it a piece of plastic trim around the steering column perhaps needs refitting?
I had similar on an old car.
Hi,
Did you get anywhere on this?
I have the same problem, sounds very much like a creaking spring..& only when steering left at low speed, also like yours it seems to be more louder when cold.
Seems like its the same on B6 Passats too:
the vague steering ,continued - VWAUDI Forum
After reading around other sites it seems a common steering rack problem as VRStu mentioned amongst the VAG group even with newer models of Octavia/Leon/Golf ...:-(
