New small mod story - roof GPS antenna retrofitted
Hello.
Till I am waiting a RNS3 (Trinax/Columbus) navi unit I changed the roof antanna:
New antenna 1U0035507A:
My factory antenna (only radio)
For changing antenna it is necessary to remove C pillar trims, rear handles, trims in luggage - a lot of work!
Antenna socket
Old antenna removed:
New installed:
Old antenna:
Excellent work :thumbup:
Looks good Andrey.
This is same ariel that is on my vRS which has factory fit Sat Nav.
I assume then, the raised circular piece ahead of the antenna is the GPS receptor?
Yes - its a patch GPS antenna - with a good clear sky view so should give excellent fixes compared with units inside the car. Don't know whether its an active one - seems to have two leads...
