Pressure washers beware!
I decided to give the L&K a bit of a once over with the pressure washer at the weekend. As I was doing the radiator grille, I noticed a bubble appearing in the chrome. The water had somehow got under the plating, and was lifting as I watched! I suspect that I'd got a stone chip in the chrome, and the high pressure jet got inside. I think I'll mention it to the dealer and act dumb..........
Phil
_______
:oops:
Phil
Ive used a Karcher since iVe had the car, and mine has a few stone chips :x
Never had that problem you describe. In fact its a must to keep those pesky wheels clean , find that if i use Tutle wax extreme wheel cleaner and the washer they come up a treat. Especially now i have greenstuff pads the amount of dust on the fronts is minimal.
In fact the rear get blacker than the fronts :wink:
Karl
Not had that, but found the badge slowly became devoid of lettering every time I pressure washed \ brushed across it...
It should say "4X4 turbo"
When I test drove it I noticed it was an "X4 turbo"
..then I collected it some days later - "X turbo"
...then after washing a few times - "turbo", followed soon after by "urbo"
So I sat down with a needle and gently lifted out the remainder of the paint (it's like a rubber compound) so now it's just embossed letters in a silver bar, which cannot be read from a distance.
It certainly seemed to fox the silver RS owner that I had a blast with this morning ;)
Phil
Karl[/quote:e44766464c]
It's excellent on wheels, definitely. But the L&K wheels are dark chrome, rather than raw alloy, so they're easier to clean anyway!
Phil :lol:
