Hello from "What's it Called?"
Hello, I'm Iain from Cumbernauld and I have a 54 plate Octvia 2.0 TDI.
(and it's steaming up when the engine is warm).
Welcome :wave:
Hello Iain,
Welcome
Someone i know with a fabia had the same problem, it turned out to be a vent that had blocked up with leaves on the panel below the windscreen wipers (you can remove the plastic panel) this causes water to build up in the area of the fresh air vent for the heater, it's worth a look.
Hope it helps.
stuart
Hello and welcome.
Welcome :)
Check the doors for leaks...
Also use the air con....
Welcome :)
hi and welcome to briskoda... :thumbup:
