Boost gauge pipe through bulk head...
I want to put a boost gauge in the centre console below the stereo.
where is a good place to run the vac pipe through on the bulkhead?
take off the glove box and behind that there is a black bung stick it though that.
Will come out at the side of the pollen filter under the bonnet
Thanks Matt - a job for next weekend!
no worries mate.
all ill say is get the hair dryer on the slam panel to remove it as it makes it so much easier
no worries mate.
Bit extreme removing the slam panel :eek::D:P
Naa just easier phil :D
And you t-piece in on the pipe to the top of the fpr?
Yes t piece it off the fpr pipe
yea ill try and dig up Robs post with the T Piece.
feck i cant find it but im sure that someone will come along with the magic picture lol
There you go..................LOL
Cheers mate i knew someone would have a close up :D
no worries mate.
I think you mean the scuttle panel :rolleyes:
hahaha i just read that back now.
Whoops
  • 4 weeks later...
Are 'Zip Ties' strong enough to hold the vacuum pipe on at boost? Dave
Another place is the grommet above the clutch pedal - needs the lower fascia removed. Gonna crack on with this over the next 2 days...
I uses the the gromit above the pedal box.
I ran my gauge in the drivers air-vent. So the pipework was better coming through the right side of the car rather than left.
i dont want to lose any vents.. i like them to clear windows, heat and cool the cabin etc lol
yeah, I know what you mean. But I found the driver's side one (in between steering wheel and door handle) never really did anything apart from annoy me (so it got closed anyway)
They sure are.:)
HTH
Mine demists the drivers side window nicely :)
Mike,
I took mine through the electrical connector box under the windscreen on the drivers side, drilled a hole in the top cover and fitted a tight grommet to feed the pipe through. I did it at the same time as i fed the cable through for cruise control :)
where did you get the t piece from. im looking at getting a boost gauage. do you get all the connectiosn with the guages or do you have to buy them separately
you normally get them seperarely.
I sell sell gauges with everything required (except some where to mount it, but watch this space ;) )
have u got a pic of the gauges u sell and a price mate?
right i got sum tubing witht the gauge. its a clear plastic one. im wonderi9ng it its going to be strong enough. does this piece of pipe need clamping too? and would a zip tie be strong enouhg in this case?
