power is gone!
Right boys driving home and a sudden loss of power.
Engine sounds rough under light and heavy acceleration (almost scooby like) and is jerky in acceleration
It also wont boost over 5psi. So does this sound like a classic misfire to anyone as i dont have VAG-COM?
Id guess that having it remapped has put the extra strain on an already slightly off coil pack??
I wouldn't be surprised if it was. Can you lay your hands on another one?
Using a spare, work your way along the row swapping them out until the problem is sorted.
If you are feeling flush then get two or even all of them.
Ive herd someone say that are only £12 each from GSF so ill get all four for that price.
Would i not need VAG-COM to clear the fault code or will it clear its self once th coil has been swapped?
The car will be fine once the packs are swapped over.
Sweet.
Im getting less of the face on now after a sleep. Just hope GSF have some in when i call them up tomorrow
THe code may remain there as history but as Manny says if that is the problem then the car will be fine.
Cheers guys.
Think ill do the plugs while im at it then as i reckon they will be about due.
£12? I paid £30 for mine. :(
That's how much they are from the stealers. First time one of mine went I had to pay £50 from the RAC!! All came back under warranty though, which was nice...
from GSF they are £16 with VAT which is a bonus.
Should i have the CEL on btw? Been reading about this and others have had the CEL come on but mine isnt.
I occasionally get the brake light on but i only thought that was due to the wear indicators (I have 2500's on so that will be why im guessing?)
I paid £24 each for mine from stealers last year, which I didn't think was too bad.:o
Mattbeef, I know that only 2 of mine had gone, but replaced all 4 anyway.
If you struggle to get one to check with, let me know & you can use my good ones untill you can get some new ones, if this is any help. :thumbup:
That a great offer thanks very much mate.
If i cant get any from GSF ill drop you a PM
:thumbup:
:thumbup:
No problem mate, I'm in Donny by the way so not too far away:D
Nice mate im sure that i can muster over to donnie in the berlingo van if needs be :D
Ok just let me know, if you need them :thumbup:
I just got 4 fitted today from euro car parts.
The old man took it for a drive and said it pulls like an express train so id say that its back :D
Ill let you know if i still need to borrow your coil packs mate as soon as i take it out
