Climate control/temp readout problem
Whenever i turn the ignition on the climate control panel lights up everything and diagnostic shows on the top.....for about 6 seconds. It then changes and works as normal
BUT
The temp is always showing -8 and it also shows that on the OBC... -8
Also....sometimes the climate panel doesnt light up:confused:
Any ideas peeps????????
If it's on both it might be a fault with the temp sensor.
where abouts are the temp sensors located???
Tiff,
I believe it is under the scuttle panel on the drivers side of the car.
Any idea what they look like
It's behind the N/S bumper grille on aq vRS. Pull the grille out and you'll see it screwed to the bumper. I can't see why the sensor would cause the display to not light or go into diagnostic mode, though. Any chance of getting VAG-COM plugged in to see what it says?
Really? My Auto data again suggested other wise, unless its on about a different temperature sensor?
Not sure what might be under the scuttle, I've had mine off and didn't see a temperature sensor. The external air temperature sensor is behind the N/S grille... I had mine off the other week.
The exterior temperature sensor is behind the nearside front bumper grill as already mentioned.
The issue may also be an internal sensor problem, there are several at different points in the front of the cabin.
it is the external temp sensor i am after
