gearbox ??
hi guys any one know the speed at which the auto gear box of skoda 1.8T shift from the first ration to the second and from the second to the third??? :confused:
That entirley depends on your driving at the time, at "General" (which is a very broad range) driving 3500 is usually normal, a little harder and youll see borderline 4, but it's a standard speed in all gears, U descide what speed it changes down at, though there are Stepped settings which it chooses by your style of driving, In simple terms it has programmed Change downs, but what one it selects depends on your throttle position.
Sounds like one for KLB. The only person I know with a 1.8T auto.
what i mean is at the highest RPM
when it touch the red
Er, I don't know for certain; I've never actually measured it. From memory (and a bit of guesswork):-
first -> second: no idea.
second -> third: more than 50MPH and less that 80 - I'd guess at around 70MPH
third -> top: around 100MPH, maybe. Not that I drive that fast, of course. ;)
Hmm... time to get out the stopwatch and find a private road :)
(EDIT: If you kick-down, it does redline before changing up)
yeah ... but i need exact value so i can calculate the HP of the car
by the way u didnt try driving @ 100MPH :confused:
i tried 145 MPH on "sure its not the true speen " but if u remove 10% it will be 131 MPH .... :eek: really fast :cool:
*dont try it at home :thumbup:
