Need help about audience mp3..
Hi everyone
I want to setup amp & sub in the boot of 0ctavia II 1.9 l&k(audience mp3 with 12 speakers)
can u please guide me how to get cd out from the audience mp3 and the remote wire +12v for the amp..
<a  href=18012008216.jpg' alt='18012008216.jpg'>
You can find a pinout diagram here -
Octavia-vRS.com - MFD2 Install Guide
From these four wires i I'll get the audio out and what about remote wire +12v???
You have an audience not a stream MP3, you've got the wrong picture.
You wnat :
http://www.octavia-vrs.com/images/images/mfd2/stream_pinouts.jpg
The Rad out should do the job you are after.
What it is worth noting is that if you already have the 12 speaker system, you are already running a sub from the speaker level outputs. This means the rad out etc will all be in use already.
It might be worth finding a suitable add on amp to this or a replacement amp that will do the speakers plus the sub
HTH
You wnat :
HTH
Today I opened my car head unit in front its showing Audience mp3 but on the top of head unit its showing stream only...
(sorry for my English)
<a  href=18012008217.jpg' alt='18012008217.jpg'>
AFAIK the black box shown beside the text means only the pin outs shown with the Black box are Only on the Stream unit, its a standard sticker for all headunits.
As Gaff said you head unit is an Audience and the stick is common to Stream and Audience.
The blacked out pins on that diagram are not present on the Audience, only on a stream unit (which yours is not).
Hope that helps
