Climate control parameters adjustment
Is there anywhere a list of what parameters my be adjusted by using the climate control, and how it is done?
TIA
John
Thanks - I'll give it a try.
I just tried this in the fabia, which has the same climatetronic as the roomster. Problem is though you don't have fan down/tempreature buttons as this is done on two kn0bs
I managed to get it to do something by holding recirc and econ and turning the tempreature dial but I couldnt get it to display any data
  • 3 months later...
for get to service menu you need to press all five central buttons on your climatronic. I didn't find speed in params, but maybe you can. I see there 52 diff params, and one more you can change most of these params Temp regulator for scrolling params, air speed regulator for changing value of param.
Cheers, that worked a treat
Doesen't appear that it displays speed/rpm/oil pressure though as you noticed:(
