Part number needed.
Oops, had a little altercation with an imovable object and managed to clop the passenger side rear view mirror on a brick wall. Speed was slow, so relatively little damage because the mirror folded in, but
The under mirror indicator lense cover is broken on the passenger side.
Also the mirror top part separated from the bottom, I think I have managed to clip it all back together and everything still works including the indicator but the outer tip still seems weak and can still be moved, however I thinkthis maybe because of the lense cover broke. The top part is undamaged apart from a small scuff that should polish out.
So anyone have the part number and price for the passenger side under mirror indicator lense cover, and how is it removed/replaced.
I have come up with 1Z0 949 101. Can someone confirm this is what I need for the passenger side mirror)(RHD).
Or it could be
1Z0 949 101B or
1Z0 949 101D
The car has the puddle lamps in the same holder, I think the one in the previous post is indicator only.
PM me a chassis No and I'll see if I can work it out for you.
Those part numbers are all right, for the same bit, but would need chassis number to really know which one. I would think all would be appropriate. They're all relevant to an '06 octavia, which I think yours is?
Looks like it is the B for yours Manny.
yep, as confirmed by my dealer. Now just need to wait for the part.
