Air Filter
Hi guys,
can any one help me ... i need to replace the A/C filter :rolleyes:
but where is it
driving 2000 oct 1.8T 4A :thumbup:
and fuel filter :o
do you mean the pollen filter on the scuttle panel - behind plastic trim under front wipers?
i am not sure .... the dealer told me the service is to change A/C filter and fuel filter and Air filter and OIL ... i think i can do it my self intead of baying 100+ euro for this job
Which mileage/age service is it as this might help to find out what needs doing :D
Chris
120k Km
The A/C filter is as Paul says the pollen filter. Located underneath scuttle panel, passenger side (in UK spec RS, can't ofcourse claim that it goes for all cars ;)).
You can see the pollen filter in this picture.
The yellow rectangle shows the position of the ECU; to the right is the TCM (Transmission Control Module - automatic transmission), and the pollen filter is to the right of that. This is a RH drive car - the positions are probably reversed on a LHD one.
that black scuttle panel , how it can be removed!!! any hiden screws
No need to remove it to replace the filter. Just lift it up and unclip the filter. Ideally a 2 man job with someone lifting the panel up a bit as it is a very tight squeeze. But it can be done. Some pictures can be found here: http://www.briskoda.net/forums/showthread.php?t=3066
The panel is not held on by any screws,
remove the rubber that runs across from left to right, VERY gently ease panel away from the windscreen by lifting the flexible rubber edge and prising out. be very very careful as it is possible to crack the screen.
