Paint Code - Forest Green Metallic
Hi there, have a second hand bumper to get sprayed and the sprayer needs my paint code. Anyone have an idea where to find it? Is it just a long number or what? It's a 2000 Felicia in Forest Green Metallic. Cheers
Hi
The paint code should be in sight as soon as you pop open the bonnet on a sticker above the headlamp. If you cannot work it out (mine is J4 J4 for Nautic Blue) look at the catalogue below which shows paint codes
http://www.jhmbuttco.com/acatalog/felicia.pdf
I believe the code for you is 1L1L. There is also a sticker by the spare wheel well with the code on it but it is likely to have worn away, especially if it is damp in there
hope this helps
Also if you have the original service history book there should be a sticker in the front of that detailing info along with paint code.
Thanks very much guys. It seems pretty hard to get paint codes for cars, have seen people on other forums having trouble with it, you'd think it'd be a lot easier to find out!
The paint code is 1L1L for Forest Green.
