Changing Tyres in Pairs?
Hi everyone,
I've got a slow puncture on a rear tyre. It cannot be repaired as the two holes are about 5cm away from each other in the centre of the tyre and the local ATS said they are too close to repair. The tyre has approximately 4mm of tread and the tyre on the otherside has 4.5mm of tread.
Do people recommend changing tyres in pairs so I'll have around 8mm on each side or can I get away with having a new tyre on one side and 4.5mm of tread on the other?
I had the same thing a while back, as they were directional tyres I changed both. Not sure on the official line?
Plus if you change one then you'll forever be buying 1 tyre at a time for the rear?
change the pair but keep the good one for a spare tyre. if the same happens again youll have a part worn one to replace it with :thumbup:
yeah change it in pairs
if it had 7 or 8mm left on it youd probably be ok as long as you used a similar tread pattern but since the tread is low you should replace both
Best to do both really and as people say , keep the good as a spare.
Ben
Thanks everyone, will change both. There goes another few hundred down the drain :(
The spare already has a new tyre on it, and there's a part worn Avon in the garage lol. Will keep the other one as a spare anyway just in case.
In an ideal world, you should change both, but I doubt you'll have any probs if you just replace the punctured one :D
Chris
You would be alright with just one new if you've not got the money at the minute. But you've spent some money there, you and the car would be a lot happier with two nice new ones, good set of tyres makes all the difference to a car.
If the spare already has a new tyre then why not get 1 new tyre to replace the dead one, put the spare on the other side and put your part worn tyre in the boot as the spare. That way you only need to buy 1 tyre - assuming you don't have a space saver spare that is!
I had 3 different makes of tyre on my Corsa by the time I came to sell it haha.
Started off with 4 brand spanking new Toyo T1-S's, one rear got a puncture within a couple of weeks :( Stuck a Barum Bavrus on there as it was similar tread pattern.
Then same happened to one of the front ones just after I'd replaced them and forced to put a Pirelli P6000 on there.
I have four Michelin Pilot Sports on the car, the spare is a Kumho Exalto something or another :rofl: Otherwise I'd have done what you suggested :thumbup:
That's what i did.
It's not that bad
You can get decent replacements (Many threads....) around the £50-70 mark each.
It's not that bad
I've used a few tyres but I love the Michelins. Just a shame they aren't cheap :thumbdwn:
It would be advisable to replace with a matching pair across the axle, however as it is on the rear it should not be that much of a problem if you dont, unless it starts to pull or feels uneasy at the back.
If you car is fitted with ESP 'all 4 wheels must be fitted with the same tyres in order to achieve problem-free operation of the ESP. Differing rolling circumferences of the tyres can lead to an undesirable reduction in engine output.'
I knew that applied to my Octavia 4X4 bit hadn't hoisted aboard that it applied to my Fabia vRs as well. I live and learn.
Same applies if it has straight foreward ABS and even normal traction control. But above very true if it has more complex ESP.
Tyre should be fine to repair...as long as the two plug patches dont overlap then all should be fine. We would do it and it would be done to a British Standard, ATS are conning you....
HTH
Phil
HTH
Phil
They said the repairs would overlap so they couldn't. The holes were pretty close together though :rolleyes:
Ok, thats cool then.... we do two types of repair 3mm or 6mm, the 6mm patch is about the size of a ten pence piece and the 3mm a 5p....Repairs above 6mm are not reccomended.
You say your happy with Michelins??? ever thought of Bridgestones??? we are selling loads at the mo;)
Phil
how a bout changing the punctured one, chuck the spare on the other and the other with 4mm into the boot to be a spare??
Phil
I have Michelins all around already and having OCD means I'd want to keep them all the same :rofl: Seriously though, I've found them to be good tyres, suit my driving style and suspension setup really well :thumbup: If I was replacing all four then I'd probably look at other tyres but for now I'd stick to Michelin Pilot Sports.
The spare is a different tyre :thumbdwn:
Just to let you all know, ATS have ordered two in at £130 each which i thought was a great price! Should have them by tomorrow afternoon. Y rated too....now wheres that remap :rofl:
Thanks for your help guys :thumbup:
Have you tried Tyres 40% Cheaper than leading tyres depots, free mobile tyre fitting they got my bridgestones for £90 Inc fitting and balance and they came to my house!
Ben
They haven't got any Michelins in my size :thumbdwn: Thanks for the link though, will try them next time I need some tyres :thumbup:
