Rear bumper edge loose, and thank you all!
Hi, I recently bought a 2004 VRS with 60k on the clock, the information and discussion in here has been invaluable, thank you everyone!
One small point, the rear bumper, the lower bit that wraps around the side of the car. One side has come a little loose, it's only hanging loose by a few millimetres but it's noticeable. The other side is tight, it's almost as if it's clipped under the wheel arch somewhere, however I can't see a clip or screw. Is there a correct method of tightening the trim or shall I drop a little superglue behind the section?
TIA!
I think mines is the same at both sides, really bugs me and i keep meaning to sort it, i'd say stick a bit of super glue under it, wont do any harm.
Maybe use some Areldite rapid for a stronger fix
