312mm Brake upgrade
As the previous poster has stated, you can retain your callipers if you have 288mm ATE brakes so only need to correct carriers.
  • 10 months later...
  • Replies 76
  • Views 12.6k
  • ok according to skoda they are: Front brakes: Disc brakes, with hollow discs, internal cooling and single-piston floating calliper. Rear brakes Disc brakes with full discs and single-piston floating
  • I promise you I'm not wrong! :P Your rears are 255x10, the vRS is 286x12, and the calipers and pads are different too.
Well two years have gone since I posted the thread and I thought I'd give a little update on how things have gone as I found the thread to give another chap some info.
Mileage has been quite high, but there is still some life left in the pads and discs.
Stopping power is still very good and I have to say for the price I really can't complain about the pads. Excellent even in the winter.
I'll probably need to change in the next year, so have been looking around at pad options (see other threads) however I've covered over 50k miles on the pads. This includes a few trips to certain German roads, so it's certainly nothing to be knocked.
Edited by cheezemonkhai
