Calipers & pads for 312mm Fabia VRS upgrade - PLEASE HELP!
Hi all,
I bought some grooved 312mm discs for my Furby vrs with some red stuff pads AGES ago, however i was told the pads would wear the discs quickly so sent them back.
The problem i've got is that that company i bought the discs & pads from said i could do the conversion without changing the calipers - when i questioned him he said he'd done numerous conversions using the standard Furby VRS calipers?!
So anyways the problem i got is that i can't find any calipers or pads unless i pay north of £100-£200 (Cheapest calipers are reconditioned ones @ £67 each + VAT)!!!!!
I was hoping for a decent 2nd set off a car that has 312mm discs as standard - any ideas on cars & where i can get some from?
Have been looking for a written off TT i can nick 'em off, but can't find one anywhere!
I need to get them quick as my current pads are nearly on the metal!
Cheers in advance for any help.
Chris
you need new calipers and carriers
I got some off ebay for £150 including postage
I've got the carriers ready and already painted VRS green, so it's just the calipers and pads required.
Have heard octy vrs ones will fit but not sure whether MK1 or MK2?
Howdy,
To do the conversion you'll need to replace both the carriers and calipers with the set off an Audi TT... The offset of the carriers for the TT caliper is different to that of the OEM Furby one...
I got a set of Audi TT calipers and carriers off of eBay for £155... awesome price for them and went on a treat! (painted with flat green Hammerite; tip: give them 3-4 coats of paint otherwise temp fatigue can flake the paint off)...
I got some 312mm Tar-Ox G88's and some Mintex Extreme pads to go with them... Experiencing many negative-G's now!!!!
Bomski
Golfturbo on here sells the full set, discs, pads, carriers and callipers. Drop him a pm and see if he can help you out :)
Whats the furby vRS std disc size ?
If it's 288 then the calipers will fit. All you need is 312 discs and carriers. Then just get pads to fit std vRS setup.
I've done this upgrade on a Bora with 288 discs and it's defo just the carriers and discs.
See that's what the chap that sold me the discs, carriers & pads said, but i always thought you'd get more braking power with the bigger calipers?!
Also golf turbo only does full kits.
GSF Car Parts, cheap car parts direct to you have got some pads off a TT for £35 + vat
eBay UK Shop - DUBSHACK COVENTRY: MK3 GOLF, MK4 GOLF, ENGINE'S also do second hand kits
The calipers arn't bigger on the TT. The breaking force is greater due to the caliper gripping the disc further from the centre of the hub.
If the vRS discs are 288, I'll put £100 down that the calipers don't need replacing
They do need replacing on the fabia VRS.
The fabia has a different caliper than the golf/bora/tt.
The calipers on the 288 golf brakes are the same as the 312mm tt ones but the fabia 288mm brakes are completely different.
For the fabia you need calipers, carriers, discs, pads and if you really want to be ok brake pipes
fair enough.... whats different ?
Physically
The caliper on the lucas fabia brakes is held in place with two 12mm bolts on the top and bottom guide pins.
The caliper on the gold version is held in place by 2 7mm allen guide pins and a sping clip on the outside.
They are just different braking systems but use the same disc :thumbup:
Random but true.
:thumbup: So much for VAG keeping the number of different parts to a minimum. Take it this is the same on polos and ibizas then.
So auroan, how many people can claim this £100??
LOL.... all bets are off. ;)
I take it this means i'll be ok using the ones off of a TT then?
Big thanks for all the input
yes TT, golf, Octy, bora . As I've just learned.
Major edit !!! yes I read the post wrong.... you do need the above
Yes! You Need The Calipers From A Tt225
nope, TT, golf, Octy, bora are a no go. As I've just learned.
Your confusing me now :rofl:
If upgrading to 312mm and you have the correct caliper hangers for the TT golf then yes you will need the TT golf caliper too.
I think the confusion is coming from the fact that the fabia lucas calipers will not fit the 312mm golf tt hangers :thumbup:
So in answer to OP you will need the calipers from a golf/tt/bora/octy :thumbup:
Okay here is another question, obviously to do the 312mm upgrade most people take the calipers and carriers from an Audi TT 225. But can you do the 312mm upgrade from the calipers and carriers from a Golf GTi Mk5? Being as that car also uses 312mm discs?
not sure about new golf, But you can use 312's off of a Octavia vRS, mk4 Golf, Seat Lion (cant remember which tho), and a couple of other vag cars.
Just got some grooved 312mm discs and mintex OE pads for £105 :)
Now my parts are complete, time to get em fitted!
Surely you could get some calipers from a 288mm mk1 octavia? Mine had 288mm discs as standard but to upgrade to 312mm all I needed was carriers/discs/pads. And am I right in thinking that the mk1 octavia vrs uses the same pads as the ordinary 288mm octavias?
