• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
Hand Brake adjustment...cannot find the thread with the info
Sign in to follow this
Followers 0
6 posts in this topic
As the title says, i need to adjust my handbrake as its getting a little high and I know I have seen a how to thread before but for the life in me I cannot find it.....help.
Share this post
Link to post
Share on other sites
Hi Stemcell
I have not had chance to mine yet, but I assume its the same as the Octavia, if it is lift the center console at the back, and there should be a adjusting nut (10mm)
I think and have the wheels just off the ground, tighten the nut till the wheels just lock, then turn the nut back 1/2 to 3/4 turn and should be ok.
I assume the disk pads and disks are ok ?
Radiotwo
Share this post
Link to post
I hope that you have fully checked over the rear brakes before trying to compensate for a "long" hand brake travel by shortening the cable. My wife's Polo is 7.5 years old nearly and has done 67,000 miles and its hand brake cable has never needed shortening, neither have any of my previous "modern" cars. Modern cables are well manufactured and should not stretch until abused - I'd reckon.
Share this post
Link to post
[quote name='stemcell' date='17 March 2010 - 11:53' timestamp='1268826804' post='1927400']
[/quote]
I prefer to adjust the handbrake as follows:-
adjust the 10mm nut until you have a max of 4 clicks when you pull up the lever.
This is more accurate than adjusting it tight ,then turning back a few turns.
Share this post
Link to post
I've recently had to adjust mine - for no apparent reason - refer [url="http://briskoda.net/forums/topic/155632-handbrake-way-out-of-adjustment-why/page__view__findpost__p__1926738"]this thread[/url]
Share this post
Link to post
[/quote]
Hello,
At the rear of the central console on your Fabia, remove/lift-out little cup-type tray, which will expose rear brake cable.
The use of a 10m/m open ended spanner is needed to turn the adjuster nut, which has flat spots on it.
As adjustment is being made by turning adjuster nut, cable will become tight then as peak of flat spot is passed, cable then becomes slack again.
Ensure your pads and discs are sound, and brake cable movement can be seen by applying then releasing handbrake, (ensure's a cable has not snapped)
Too much tension on cable will not let it return to correct rest position at rear of caliper.
MOT testers generally look for 4 clicks to fully lock up rear brake, not to be confused with maximum hand-brake travel.
Good luck.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
