air con problem
Recommended Posts
Shutoff code 12 means that ECU has sent a shutdown request via CAN. It usually does this when the engine is starting or accelerating or the idle speed is undercut.
What happens if you raise the engine rpm to a constant 1500rpm?
Can you post all the data as you did in #16
Link to comment
Share on other sites
compressor shut off code 12
engine speed 1500/min
vehicle speed 0.0km/h
standing time 01:31
compressor current actual
compressor current specified 0.000A
compressor speed 0/min
compressor load 0.0Nm
coolant pressure 3.0bar
rad fan activation actual 10.0%
rad fan activation specified 0.0%
engine speed increase OFF
Link to comment
there is the readings have you any idea what i need to do get it working.
when i fitted the new compressor it changed the shut off code from 16(compressor activation faulty) to shut off code 12(shut off requested by engine control)
so i dunno how to sort it out now
Link to comment
The coolant pressure is too low. A static pressure of 3.0bar corresponds to an ambient temp of less than zero. You are either low on gas or have a faulty pressure sender.
My guess is that you are leaking gas. In post #16 the pressure was 5.6bar which seemed OK.
A manifold gauge set will allow you to confirm the pressure sender reading.
Link to comment
Nope not leaking I just Replaced the compressor and then took it to get regassed. But he said there was no point putting more gas in if it isn't working. So going back to get the rest off my gas tonight.
Link to comment
  • 4 weeks later...
Hi,
After changing the compressor, it is mandatory to do a Compressor first time Run-in process, which can be initiated in the basic settings for the HVAC controller. Select Manual Run-in and the AC light on the dash will blink when you start your Yeti. Press the AC button and it will start the Run-in process (typically around 120sec). After this is completed, the HVAC controller and ECU controller will be tuned to each other for the new compressor. This may resolve the error that you are getting.
Regards,
Sameer
Edited by sameerdass
  • Like 1
Link to comment
  • 8 months later...
Does anyone have any ideas how to get the pressure sensor switch off without dismantling half the front on my mk11 octavia? Its leaking form it and got a new o ring but going to be hell to try and get the the bolt head underneath the switch.
Link to comment
Petrol/Diesel? Engine? Year? Climatic/Climatronic?
Pressure Sensor or Pressure Switch?
In either case, you unplug the connector and use a spanner to unscrew the sensor or switch. Before you do that, you need to recover the gas.
Link to comment
If it helps I've just changed my Sensor G65 because of a intermittent air con, no need to remove any parts all I did was bend a 17mm spaner at the head so it looks like a crows foot, also no gas was released there was a valve inside the small pipe the holds the sensor that looks like a normal tyre valve type thingy.
Result - air con still intermittent
Link to comment
This might be a real numpty question, but here goes...
At what point do you start the engine when using VCDS? Before plugging in? After plugging in but before starting software?
I don't want to damage anything but I do want to diagnose my air con problem.
The compressor speed is showing as 0 (zero) rotations despite being on (engine not running) which doesn't look good!
And current is 0.0A
Shut off code is 7 (when Climatic switch is off) and 5 when air con is running.
If someone can tell me when to start the engine I'll be able to have a better look.
Link to comment
If you are retrieving fault codes, you don't need the engine to be running - you just need the ignition on. It doesn't matter if you do start the engine - you can still read the codes.
The compressor speed will be zero if the engine is not running as it is driven by the engine. You need the engine running to read compressor speed and this is the case for many other parameters.
If in doubt, run the engine.
Link to comment
I guessed that the compressor wouldn't be running if the engine wasn't, but can I plug the VCDS cable in before starting the engine or is it safer to plug it in after the engine has been started?
Link to comment
As there are some knowledgeable people already in this thread, I hope you won't mind me adding my data to see if there is any similarity.
Mines a manual diesel Octavia II ('07) without the Climatronic controls (standard Climatic controls only the Ambiente).
Engine Idle:
Shut off code: 0.0
Engine speed: 800/min
Compressor current (Actual): 0.560A
Compressor speed: 1000/min
Compressor Load: 6.4Nm
Coolant pressure: 12.0 bar
Radiator fan Activation (actual): 46.8%
Outside temp (filtered): 18.5 C
Outlet Blower Temperature: 8.0 C
Interior Temperature: 33.0 C
Accelerator peddle depressed:
Shut off code: 0.0
Engine speed: 1500/min
Compressor current (Actual): 0.610A
Compressor speed: 1900/min
Compressor Load: 5.7Nm
Coolant pressure: 14.0 bar
Radiator fan Activation (actual): 60.8%
Outside temp (filtered): 19.5 C
Outlet Blower Temperature: 10.0 C
Does this give any clues as to why my Air Con is not running very cold (it is colder than on Econ settings, but no where near as cold as it should be)?
Had it re-gassed last month as it had never been done - not because I thought there was a problem - but the mechanic asked if I was experiencing any problems with it. He recovered the gas, cleaned the system and re-gassed it to the correct pressure.
For the rest of that day the air con ran much colder than normal. Next day it was not quite as good then after that it was back to 'normal'.
The system he used to do the regass didn't pick up any problems with leaks, etc. so I'm a little stumped!
Compressor seems to be OK. No leaks (so I am told).
Have I misinterpreted something in this thread and am I reading the data wrong?
Or is there a specific problem that I don't know about? Yet.
Link to comment
You should be able to get down to 7degC given an outside temp of less than 35degC, so you are not that far away at 8degC. In fact the compressor has been instructed to throttle back as the outlet blower temp is approaching the set temp (the N280 duty cycle/compressor current is not at maximum). A compressor current of 0.8A is 100% duty cycle.
The high side pressure seems OK, but without knowing the low pressure I can't be certain that there isn't a minor problem. The system should be filled by weight - not pressure as is dependant on temperature and this is almost impossible to determine. Whilst the fill is 'in range' the refrigerant might be a little low. A manifold gauge set (or the gauges on an a/c station) would tell you.
If you were used to a MK1, then you will be disappointed as the MK2 doesn't have the same cooling capacity.
  • Like 1
Link to comment
Having major problems with mine , I'm fairly sure its the compressor , shut off code is 3 , if anybody knows what that is but its leaking badly in the compressor area
shut off code 3 is Low Refrigerant Pressure
  • Like 1
Link to comment
I never had a Mk1 but have had other cars with better air con.
What got me thinking was the guy at Midlands VW asking if I'd had a problem with the air con when he was regassing it. He then said that they are normally much colder than mine was.
His reason was that the compressor was on its way out, but not dead yet. Does this seem likely with these figures?
However, when I drive away the air con was very cold, as cold as any other car I've had. It just didn't last...
Can I check lo-side pressure with VCDS?
I'll also check vent temp when I can find a decent thermometer.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
