AMF BNV engine swap.
Recommended Posts
Hi all,
I have a 1.4 tdi PD 80 fabia estate, on a 57 plate, which has a seized engine due to the oil pump failing at 70000 miles. ( not as uncommon as I first thought after doing some research ).
Basically, I have been quoted £700 for a second hand one fitted, but it has the AMF engine code and my present engine has a BNV engine code.
What if any is the difference between the 2 different codes ( is it just an age thing ) and would this be an advisable replacement.
Thanks in anticipation.
Link to comment
Share on other sites
By looking at the wiki page, it looks like it is most likely a mapping difference on the exact same engine build (bar a few minor alterations im sure). Should be fine.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
