Mobil 1 engine oil
Recommended Posts
I have had Mobil 1 in the car for a week now, after an oil and filter change, and can't help thinking the engine seems noisier. I don't record mpg, but that also seems a little down. Anyone else used this oil and noticed anything different? I thought I was buying the best available for my 1.9 PD
Link to comment
Share on other sites
In my bike, Mobile 1 is the oil which makes it run best, quieter, cooler and feels livelier.
A PD engine needs special anti scuff, anti wear additives because the camshaft also drives the unit injectors which mean the cam lobes are rather narrow and as a result rather stressed.
I don't know which of the several Mobil 1's you used or even if it is approved to meet the requirements of VAG for this engine
On the container it should say 505.01 for normal 10,000 mile oil changes, or 506.01 for extended "longlife" oil changes.
There is also 507.00 which would also do.
http://www.oilspecifications.org/volkswagen.php
Link to comment
I'm running Mobil1 504/507.  It's no noisier than any of the previous oils I've had.  In fact, it's running so smoothly I've been trying to work out how to reduce the idle speed 50-100rpm.  Fuel economy is good too.
This is a TSI engine, not diesel.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
