Handbrake and drums
SkUG
Recommended Posts
Fitted new cables, adjusted handbrake to a few clicks, ran out of adjustment again few months later, anything else worth changing? Pads still have plenty of meat on em, no hint of a lip on the drums
Cheers peeps :)
Link to comment
Share on other sites
The little automatic wedge adjusters on the shoes are useless. Take out a wheel bolt line up to wedge. Use long tapered pokey thing to nudge wedge up and down till shoes just off touching ( handbrake off). Fine tune with nuts on cable after pumping brakes and activating hand brake a few times.
Link to comment
Brakes adjusted out when fitted, useless adjusterers cleaned and freed up and adjusted, cable stretch adjusted for stretch and now back to out of adjustment after a few months - can the handbrake handle end stretch?
Link to comment
My handbrake on my 1.2 has been getting progressively worse over the last few weeks (adjusted every couple of weeks). Cable adjustment nut is all the way in now and checked self adjusters, think it might just be stretched cables.
Think there about £15 for new cables but why do they last such a short amount of time?
Link to comment
The wedges should be properly adjusted before tweaking the nuts near on the handbrake - if the auto adjust aspect doesn't any more, you will have to do it manually every now and again. Slacken the nuts back off to untension the cables and get the wedges right then tighten as required.
  • Like 2
Link to comment
Of course, the other fairly common issue would be brake fluid leaking from rear cylinder(s) causing a reduction in braking efficiency for any given force from the brake shoes. Have to remove drum to look for this although a loss of brake fluid at the master cylinder would eventually give this away.
Link to comment
That wouldn't affect cable adjustment.
It's possible that the cables, if they are non-genuine ones, might be manufactured slightly too long. I've had this happen myself.
Edited by TMB
Link to comment
Except in that the cable would need to be tighter for the same degree of handbrake effectiveness.
Yes but the cables would still adjust. It may not hold the car if there was fluid contamination but the cables wouldn't be slack.
Link to comment
I've never liked the handbrake action on the Wife's SDi. Even with new cables, shoes and drums and further adjustment after a month of use I feel the lever travel is too long. However, it holds the car firmly so I'm not too concerned. Too cold to faff with cars now.
  • Like 1
Link to comment
No fluid contamination, new cylinders at same time as cables. All cleaned with brake cleaner, adjusterers frees up, Cables slackened, adjusterers adjusted until wheels binded slightly and then adjusted  cables back up, few weeks later back to hitting the ceiling and no more adjustment on the cables
Link to comment
Where did your replacement cables come from, and what part number were they?
Do the cables pull up approximately evenly at the 'spreader bar' in the cabin, or does it skew off as the lever is raised?
Edited by Wino
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
